Fix one thing and other pops up
Old Oct 4, 2007 | 06:17 PM
corvair024's Avatar
corvair024
Default Fix one thing and other pops up
Well I finally got the idle perfect and all the power (if not more seemingly) back on my 1996 Dakota 3.9 5speed. The problem was I had an exhaust leak on the drivers side due to a mounting bold on the manifold being sheared off. I extracted the sheared bolt, new gasket, new bolt and it idles and runs perfect. That is until all of a sudden a screeching noise coming from either the belt or a pully. I carefully listened to it and could have sworn it was coming from the tensioner pulley, so today I replaced it. Started it up and still the intermitent screech. I didnt think it would be the belt itself because I replaced it 10 months ago. The tensioner pulley I pulled off had a lot of play to it and it def. needed to be replaced as the bearings seem almost shot. The tensioner itself was frozen it I PB blasted it and worked it free and now have coated it in WB-40 to keep the rust out. Could this have killed my belt? Just pulled the idler pulley a min ago and its bearings seem to be fine other than when I shake it I can hear the bearing rattle or spin it I hear just a slight intermitted grind like a piece of dirt in it. So I am at a loss if it is the idler pulley or the belt. Any advice would be greatly appreciated. Thanks!
Kevin
Old Oct 4, 2007 | 08:22 PM
iraqvet's Avatar
iraqvet
Default RE: Fix one thing and other pops up
maybe try a mechanics stethescope or a piece of metal rod and place it on/near the alternator, power steering pump, ect and see if you can pinpoint the noise... you may also try spraying a little WD on the belt itself but don't saturate it.
Old Oct 4, 2007 | 10:43 PM
Nicegy525's Avatar
Nicegy525
Stethoscope to pinpoint where the noise is. otherwise its a guessing game. Also check your pulleys for dirt andcrud that could be clogging the grooves in the pulleys.
Old Oct 6, 2007 | 09:32 PM
corvair024's Avatar
corvair024
Well to continue the saga of making my truck just run right...found the source of the sound very fast. My water pump locked up about a mile from my house. Looks like the impeller blades gouged into the surrounding metal and locked it. Bought a new water pump today and got half way through installing it before I ran out of daylight. Will update you guys tomorrow on how it runs after the install.
