Smells like Fuel
Smells like Fuel
Just recently my truck started to smell like gas. I describe the smell as 'fresh' unburned fuel. Almost like if you had a gallon of gas sitting in a bucket that kind of smell. I only notice the smell if I'm sitting at a stop sign for more than say 30 seconds or after I'm done driving. I just filled up the other day and the mpg stayed at 17 which is average for my driving style. I checked for leaks but haven't found one.. yet at least.
I also checked for codes and it did come back as 32.
Only mods are very simply, K&N FIPK intake, and a different muffler (glasspack) cheap cherrybomb.
1993 Dakota, 4x4, 3.9 V6, 5 spd.
Any ideas of what to look at?
Trending Topics
RE: Smells like Fuel
I had a leak in the same place your describing. The fuel line was rubbing on the bottom flange of the firewall. I used some JBWeldto plug the hole and also massaged the flange flat (beat the hell out of it with a hammer). It's been a little over a year and it's still not leaking.
Yep I'll try that. Doesn't leak while its running though, I let it sit idle for a few minutes in garage and nothing. Drove a couple miles and sat in garage again for a couple minutes at idle nothing. Turned it off, and with in a minute I saw a little drip, and where it was coming from. At least it doesn't while its running though, but I need to fix it and will.
