Fuel Filter
Old Oct 29, 2007 | 07:34 PM
FoxRocker's Avatar
FoxRocker
Default Fuel Filter
Hey guys, im having a problem with my 1995 Dodge Dakota 5.2L V8, Just wondering if anyone knows where the fuel filter is located? how much work to replace it, and the easiest way to do it.
Please let me know
Thanks
Old Oct 29, 2007 | 09:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: Fuel Filter
It is on the driver side, inside the frame rail. Just passed the gas tank. It is simple. I belive it may have some specail retainer clips. If you can get it appart with out damaging it. I have hose claps holding mine and I cant remember if that was stock or not I replaced it a long time ago. It is easy to do just pull the fuel pump fuse and start the engine, Let it die. This is the easyest way to relase the fuel pressure.
Old Oct 29, 2007 | 09:35 PM
95V8Dakota4x4's Avatar
95V8Dakota4x4
Apparently mine is inside the gas tank...
Old Oct 29, 2007 | 10:04 PM
FoxRocker's Avatar
FoxRocker
Any pics or diagrams showing the location?? thanks guys
Old Oct 29, 2007 | 11:46 PM
Bad96_3.9's Avatar
Bad96_3.9
i think they are in the tank from the factory, that must be an aftermarket one Crazy4x4RT.
Old Oct 30, 2007 | 12:18 AM
fox's Avatar
fox
ok i looked on my CD mamual and from 1989-93 all the fuel filter are where crazy described. on 1994-96 the filter is in the tank.
Old Oct 30, 2007 | 12:34 AM
FoxRocker's Avatar
FoxRocker
well i quess im gonna have a fun time doin that filter then.
Wat do you guys think would be the esier way out? drop the tank, or lift the box, and then just pull out the fuel pump assembly with the filter??
Thanks for your help..
Old Oct 30, 2007 | 03:04 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I guess ur right fox! i know its the same way with the fuel pressure reglator too. i have an internal tank filter too. and an external as well here is a pic. sorry to you all confused!
[IMG]local://upfiles/70180/406EA53CD9744D8A903B82EBCC7236C0.jpg[/IMG]
Old Oct 30, 2007 | 10:54 AM
put it to the floor's Avatar
put it to the floor
i tried replacing the feul filter on my 94 dakota and it is in the tank and trust me it is a lot easier to lift the box off then to drop the tank also if you lift the box off it makes for real easy acsess
Old Oct 30, 2007 | 08:48 PM
Bad96_3.9's Avatar
Bad96_3.9
i wish i had an external fuel filter...... too bad i am about to get rid of the electric fuel pump anyways!
