92 3.9l to 92 5.2 swap
Old Nov 5, 2007 | 07:59 PM
Ruggels's Avatar
Ruggels
Default 92 3.9l to 92 5.2 swap
ok so im curious
most parts are identical on both engines...
i just wanna know what i should be expecting to change besides the wireing harness.....
will oil pan clear cross member on my 3.9l 4x4 ?
any surprises ill have i knowthe mounts are the same etc
what about the ecu . ?
i have 2 complete trucks so you know ... im putting the 318 into my 92 4x4 .. with a 3.9 ...
all info is greatly appreciated
Thanks
Kirk
Old Nov 5, 2007 | 09:11 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: 92 3.9l to 92 5.2 swap
If it is 2wd which Im guessing because of your sig.the pan will not, it will have to replaced, with a 4wd. I belive the 4wd oil panshave a dimpleon it to clear theaxle.The ecu will have to be the 5.2 as well as the wiring harness. But you dont have cut just disconnect it from the fire wall and everything will just plug in the same. As long as the 5.2 has ac and if ur does, if one doest then you will have to cut it in to add it in. Same with 4wheel abs if you have it dont mess with those wires.
Old Nov 6, 2007 | 12:17 AM
Ruggels's Avatar
Ruggels
niether has the abs i dont think the 5.2 has ac but im just gonna d/c the ac i dont need it nor do i care for it .. now the oil pan has to come from a 4x4 5.2 ? or can i put the one from my 3.9l ?
Thanks
Old Nov 6, 2007 | 02:32 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Well I just checked autozone.com and the 2wd and 4wd had the same part number for the oilpan. So I guess it dont matter. And the v6 oil pan would be too short for v8. Good luck with it.
Old Nov 7, 2007 | 06:58 AM
Ruggels's Avatar
Ruggels
ok so back to the wire harness ... the truck im putting the 318 into has no ac .. but the wire hardness from the 2wd had ac does it matter if i dont cut nothing ... just wont have an ac to hook up is all ?
lemme kmow please ?`
Old Nov 7, 2007 | 01:44 PM
Crazy4x4RT's Avatar
Crazy4x4RT
just take the entire under the hood wiring harness and computer you will be fine
Old Nov 7, 2007 | 09:32 PM
Ruggels's Avatar
Ruggels
kk sounds good sorry if i sound annoying lol do i need to cut it or just unplug lol ;P
Old Nov 7, 2007 | 11:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
just unplug
Old Nov 8, 2007 | 11:00 AM
Razoroth's Avatar
Razoroth
Hey Ruggels. I have a question for you regarding your 92 2WD. What do you plan on doing with the truck after the swap? Are you putting the 3.9l engine in it and still selling it? or will this become an empty parts truck? The reason I am asking is because down here in Louisiana where I live, I've been having trouble finding parts for my 92 3.9. I found one truck in Mississippi, but most ofthe parts i need are already taken. It's mostly cosmetical parts and interior cosmetical parts, but there's a long list, lol. I'm looking for a mostly intact 92 that has or had a 3.9 in it because engine parts are needed too, but not so much i can't still currently drive my truck. This truck is our only vehicle and this is why i need to find a parts truck for it. If you DO plan on selling it for parts, hit me up with a price and a general area where i would be getting it from, because I would need to assess my finances to see if I could handle the price + cost of pickup. Thanks in advance, and good luck with your swap, I've been thinking of dropping a 5.2 into my 2WD myself and I know this has got to be a big job (considering I have NO major equipment but a jack, haha).
-Raz
Old Nov 11, 2007 | 01:06 AM
Ruggels's Avatar
Ruggels
well what i been reading lol everything bolts right up so besides removing the engine and putting it in my 4x4 i don tsee it being that big a deal with a few pairs of hands and some know how from someone lol
and as for the 2wd ext cab not sure what im gonna do with it lol probably sell it with the 3.9l in it or in the box lol ;P
talk to you soon @
