Cutting springs.
Cutting springs.
I just put 3" blocks in the rear of my 93 Dak, and want to lower the front for a straight stance. I bought some of those coil springs clamps at autozone, but am kinda weary about them popping off, or moving around. Has anybody ever cut the coils on the front of one of these? If so about how much did you have to cut off? I am building this truck for show, and not really going to drive it much, so the ride doesn't concern me.
Thanks guys.
Thanks guys.
RE: Cutting springs.
I've cut coils on previous projects were no aftermarket springs or spindles were available. I'd say try cutting one coil wrap at a time and use a cut-off tool or plasma cutter to make the cut - never use a oxy/acetlyene torch. Personally, the Dakota springs were the hardest springs I've ever put in since they are short, under high tension and the a-arms don't have a lot of travel. You may want to opt for spindles of you have the money....I think I've seen them on eBay for under $250.
