'87 3.9 Automatic Transmission Fluid
Old Nov 27, 2007 | 12:57 AM
uepete's Avatar
uepete
Default '87 3.9 Automatic Transmission Fluid
Ok I keep hearing conflicting information and would like some other opinions...
I was told at the auto parts store that for the 87 Dakota 3.9 that I regular Dextron/Mercon ATF is just fine. From others I hear to NEVER use Dextron in the Dodge trannies.
Any suggestions and why?
Old Nov 27, 2007 | 08:50 AM
iraqvet's Avatar
iraqvet
Default RE: '87 3.9 Automatic Transmission Fluid
The shop my aunt had taken her 93 Dakota for years flushed and filled it with Dextron every two years or so. When I was given the truck (now with 300K plus miles), she said the transmission was replaced once a few years ago but I can't say the Dextron killed it....I continue to run Dextron in it and it shifts fine. When I dropped the pan a few months ago, the fluid was pretty clean.
Old Nov 27, 2007 | 01:58 PM
fishlessman's Avatar
fishlessman
i found this when i changed to atf4 a few years back, it only goes back to 89. maybe someone knows if the tranny 2 years earlier was different. my 89 definately runs better with the atf4
Old Nov 27, 2007 | 02:15 PM
fishlessman
forgot the link
http://www.dodgeintrepid.net/forums/...p/t-39190.html
Old Jan 20, 2008 | 09:33 PM
mopar400's Avatar
mopar400
Don't use anything other than ATF3 or 4. It would call for ATF2 ,3&4 are the replacements. Mercon dextron are only for old dodge trucks like 70's and older
