chrysler 8.25
Old Nov 27, 2007 | 03:14 PM
300hp318's Avatar
300hp318
Default chrysler 8.25
i am about to upgrade the stock rearend and was wondering what yalls opinion is on this. should i go limited slip, posi, spool, or locker? which company do you suggest that i use?
thanks
Old Nov 27, 2007 | 04:47 PM
fox's Avatar
fox
Default RE: chrysler 8.25
I got the stockchrysler sure-grip (AKA) a limited slip and its works awsome, sucks to make U-turns but still works great off-roading. Its a cone clutch type I beileve.
Old Nov 27, 2007 | 09:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Well I guess it depends on what you will be doing with your truck. Like if you offroad alot. Maybe a full locker. If you drive more street. go with a lsd. Maybe to go with the locker of you get, grab some lower gears. Give youmore torque. I have a powertrax noslip. full locker. with 3.9 gears.
Old Nov 28, 2007 | 09:39 AM
300hp318's Avatar
300hp318
im not worried about torque. i got 425 ft. lbs. i found a limited slip for 300 bucks. but one other question i have that know one seems to know is if the A500 is worth building as a hot rod automatic? does anyone know anything about these?
thanks
