93 Dakota
Old Nov 28, 2007 | 08:53 AM
Zemo's Avatar
Zemo
Default 93 Dakota
I have a 93 Dakota with 180,000 miles on it. It will not start, I have changed the fuel pump, but did not help it. I figured out that i have no spark. I was told that would shut down the fuel. Was wondering if anyone had some suggestions since i have changed the pump and did not help.
Old Nov 28, 2007 | 11:34 AM
partsman31523's Avatar
partsman31523
Default RE: 93 Dakota
disconnect the coil wire at the coil and turn it over. if you have a spark there then reconnect your coil wire and check for spark at the distibutor cap. (the other end of the same wire).
If you have spark there, check for spark at each of your plug wires.
*********IMPORTANT!!! DO NOT HOLD THE WIRE WHILE SOMEONE TURN THE ENGINE OVER. YOU WILL GET SHOCKED!!!**************************************** ***********
Old Nov 29, 2007 | 03:47 AM
flyers win the cup's Avatar
flyers win the cup
check out FAQ on this site. daks have a wiring problem that's described there.
Old Nov 29, 2007 | 08:12 AM
Zemo's Avatar
Zemo
I read on here yesterday about a wire corrison problem under the large fuse box under the hood. I went home and guess what a wire was corrioded in two. I want to thank this forum it was a savior to me.
