fully built 318 swap
Old Nov 28, 2007 | 12:26 PM
300hp318's Avatar
300hp318
Default fully built 318 swap
i have a 91 dakota with a 3.9l v6. and i have a 68 318 with 10.5:1 pistons, chromolly rings, fireball cam, 40 thousandths of the heads, edelbrock low rise intake, edelbrock 600cfm electric choke, custom painted elite series valve covers....anyway i plan on putting this motor in this truck over christmas and wanted yall opinion.
thanks
Old Nov 29, 2007 | 12:32 AM
wink2873's Avatar
wink2873
Default RE: fully built 318 swap
do it. since that 318 isnt fuel injected you may have issues though.
Old Nov 29, 2007 | 04:18 AM
flyers win the cup's Avatar
flyers win the cup
crap, crap, crap, i want one
Old Nov 29, 2007 | 09:37 AM
300hp318's Avatar
300hp318
what do you mean since the 318 isnt fuel injected i may have problems?
Old Nov 29, 2007 | 01:52 PM
Crazy4x4RT's Avatar
Crazy4x4RT
When you say "40 thousandths of the heads" do you meen decked or milled down. I got mine .030and I had trubble lining up the intake with 30 thohow was 40 tho. did you bore out the engine? Did you deck the block? I decked my block .015
Old Nov 29, 2007 | 02:33 PM
300hp318's Avatar
300hp318
The heads were milled down and yes it was hard to put the heads on. and the intake took some time to. The block was decked. No i didnt bore the engine out. Its still a 318.
Old Nov 29, 2007 | 02:40 PM
Crazy4x4RT's Avatar
Crazy4x4RT
how much you deck the block? Why was it hard to put the heads on. The only trubble would have been the intake.
Old Nov 29, 2007 | 02:46 PM
300hp318's Avatar
300hp318
i dont know how much the block was decked. i meant the heads were easy and the intake was hard to put on. my bad
Old Nov 29, 2007 | 08:26 PM
wink2873's Avatar
wink2873
i mean that the 318 is carbed so it wont use a computer, your truck wont know what to do. the engine and transmission have to "talk to each other".
Old Nov 29, 2007 | 09:10 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
.040" is borderline for stock pushrods. You might run into low cylinder pressures. If so, you'll be using adjustables.
And FWIW, chromoly rings are not worth it. They take 4-EV-R to seat. I'll never use them again after the blowby issues I had on my 360. They actually let enough past that I hadcrank casedetonationfrom fuel vapor buildup and blew the valve covers off on a hot start.
