Wiper Linkage Help
Old Dec 2, 2007 | 03:48 PM
Juicy's Avatar
Juicy
Default Wiper Linkage Help
ok a few weeks ago i decided to try to fix my windshield wipers, because they were loose, well i took the linkage out to replace the bushings but ran out of time, so now that i have the bushings i can't seem to get the linkages back in the way they came out, they keep binding up so if so one could tell me what order and which way they go in that would be great. thanks.
Old Dec 4, 2007 | 04:52 PM
kahanabob's Avatar
kahanabob
Default RE: Wiper Linkage Help
I was waiting to see if someone could give you exact info. I have changed mine and did get it mixed up. You will just have to try differant ways until it works. Turn the linkage over as well as switching the ends around. You will have needed toinstalled the nylon part into the linkage the same way it came out. Those you can get in backwards. If you poped out the old parts then walked away from it and now don't know which side to put them in from it will be a bigger problem. Hopefully you took out the old one and poped in the new one on the same side. Sorry i can't be more specific.....
