Shift lever indicator loose
Old Dec 8, 2007 | 05:16 PM
jjones31's Avatar
jjones31
Default Shift lever indicator loose
I have an 89 Dakota on which the column shifter position indicator does not match the transmission. It's always too far to the right by one position. If it's in park the indicator says reverse, in reverse it says neutral, etc.
How difficult is it to adjust the indicator and what is involved?
Old Dec 8, 2007 | 05:53 PM
OneBadKota's Avatar
OneBadKota
Default RE: Shift lever indicator loose
It's not hard to adjust, it's hard not to break the line, in my case anyways. There's a little fishing line like string on the indicator, it has a specific spot on the column to wrap it up.
I tried mine, it broke. Tried to tape it, holds for a little bit.
Hope this helps. Good luck.
Old Dec 9, 2007 | 12:51 AM
Bad96_3.9's Avatar
Bad96_3.9
i wrapped mine up and it has held ever since, luckily i did not break it, mabey you can get lucky...
Old Dec 9, 2007 | 12:54 AM
Danny~G's Avatar
Danny~G
yeah it brakes easy i used duck tape so far so good
