air cleaner
Old Dec 8, 2007 | 11:17 PM
slugshot_90's Avatar
slugshot_90
Default air cleaner
anyone know were i can buy a new air cleaner for my 96 dakota 3.9L i just bought a edlebrok CIA but i has a little gap in it and i lost the head the factory air cleaner so i need to buy a new one
Old Dec 9, 2007 | 02:55 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: air cleaner
http://store.summitracing.com/partde...p;autoview=sku
Or any air cleaner set up should work from any magnum engine.
Old Dec 9, 2007 | 07:37 AM
slugshot_90
well i have one of those its an edelbrock i just need to get a spacer for it cuase its hitting a hose and makeing th eintake have lift a tiny bit to have the engine exposed, or is there anyway i can take the screw of were the intake goes and put a CAI from a 97-99 dakota
Old Dec 9, 2007 | 11:35 AM
Crazy4x4RT's Avatar
Crazy4x4RT
what hose is it hiting! take a picture!
Old Dec 9, 2007 | 01:06 PM
Bad96_3.9's Avatar
Bad96_3.9
i measured my throttle body a while ago and i think it it the same as a 4 barrel carb, you may want to double check though...
Old Dec 9, 2007 | 03:18 PM
slugshot_90
i though it was getting stuck on the hose but i found out its getting stuck on a little bolt
some told me to get a spacer and a bigger bolt for it but im not sure what spacer to get if some one could post a link of the spacer for this
Old Dec 9, 2007 | 03:57 PM
slugshot_90
i mean could i just put the cia for a 97 dakota on this with the 3.9L
Old Dec 9, 2007 | 07:32 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya a throttle body spacer would work for you. They dont add power like the clam but for you it is perfect to space it. Or get a smaller diamater air filter. or if you canmake a small dent in yours to clear the bolt.
Old Dec 9, 2007 | 10:50 PM
bionic4.0's Avatar
bionic4.0
auto zone sells air cleaner spacers
Old Dec 9, 2007 | 10:59 PM
slugshot_90
but do i need tog et a taller bolt and if so were can i get one
