p0300 & p0304 Help
Old Dec 10, 2007 | 06:52 PM
5.2_Magnum_Sport's Avatar
5.2_Magnum_Sport
Default p0300 & p0304 Help
i've got a check engine light on and got codes p0300 & p0304,i checked the plugs it has fairly new champions # 4071 and wires,dist cap has no moisture in it and no cracks,i swapped # 2 & # 4 cylinder,cleared codes drove truck for a few minutes light came back,still has p0300 & p0304.Any ideas where i can look next?
Old Dec 10, 2007 | 07:56 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: p0300 & p0304 Help
whatthose codes pull up?
Old Dec 10, 2007 | 07:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Do you fell a miss on it. Because according to the comp. You should be. If you dont and everything feels fine. It might be you distributer mod. or the crankpostion sensor. If you do feel the miss you should replace your wires and plugs and cap. it should be about $30 for it all. That is cheap insureance. You could try cleaning up your injectors as well.
well here are what the codes meen. Im sure you know but for others to know too.
P0300 (M) Multiple Cylinder Mis-Fire Misfire detected in multiple cylinders
P0304 (M) Cylinder #4 Mis-Fire Misfire detected in cylinder #4
https://dodgeforum.com/forumid_108/tt.htm
Old Dec 11, 2007 | 09:25 AM
5.2_Magnum_Sport
Yea, I can feel the miss,In fact i could feel it start missing a little before the light came on and before i could get to Auto zone to check it,it came on.The truck used to belong to my brother and he was real good about maintence on it,I'll start with a Cap & Rotor,and work my way round...thanks
Old Dec 12, 2007 | 01:14 PM
5.2_Magnum_Sport
Replaced Cap & Rotor...miss still there(cap was corroded rotor was too)anyway,friend of mine suggested moving #4 injector to #2...i did...misfire moved to #2...replaced injector...WALA....fixed...Thanks
Old Dec 12, 2007 | 01:39 PM
dodgerules86's Avatar
dodgerules86
Good to hear you got the problem fixed.
