Once in awhile this happens...
Old Dec 10, 2007 | 09:16 PM
92BLACKLS's Avatar
92BLACKLS
Default Once in awhile this happens...
Does this ever happen to anyone?
Once in awhile when its usualy cold, after I hit the remote start and let the truck warm up, I'll back up and then stop completely and put it in drive and it shuts off like I have stalled a manual transmition, does it even if I dont warm it up, has this happen to any of you?
Old Dec 10, 2007 | 09:26 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: Once in awhile this happens...
that happened when i first got my truck, how long since you had a good tune up? run some fuel injector cleaner trough it and mabey some seafoam trough the pcv line. drive the **** out of it for a little bit and blow all the carbon out too.
Old Dec 10, 2007 | 10:50 PM
92BLACKLS's Avatar
92BLACKLS
I've done the seafom but straight through the trottle body, didnt think about the pcv tube..... probly a good idea to do again, I've never ran injector cleaner, im a lil fishy about doing that to cuz i hear its good or bad no grey area. Probly due for a plug chang though...
Old Dec 10, 2007 | 11:14 PM
Bad96_3.9's Avatar
Bad96_3.9
try the lucas fuel injector cleaner, it is the best in my opinion.
Old Dec 10, 2007 | 11:22 PM
95V8Dakota4x4's Avatar
95V8Dakota4x4
It just stalls out? I think it's more than a tune up issue. Clean your IAC passage and examine the valve.
Old Dec 10, 2007 | 11:59 PM
92BLACKLS's Avatar
92BLACKLS
Hmm could be that to, I haven't cleaned it at all since I got it because the idle was bad or rough.
Old Dec 11, 2007 | 12:28 PM
Nicegy525's Avatar
Nicegy525
mine does it but not too often. it has always fired right up after though
Old Dec 11, 2007 | 05:26 PM
92BLACKLS's Avatar
92BLACKLS
Yea so does mine, she fires up right quick
Old Dec 11, 2007 | 07:03 PM
WVU's Avatar
WVU
mine was having that same problem.. I pulled the IAC off and cleaned it up solved the problem right a way..... Hope this helps....
Old Dec 11, 2007 | 10:37 PM
92BLACKLS's Avatar
92BLACKLS
Hmm. so it's looking like the IAC, next time if it happends then I'll pull it off and clean the SOB.
