Dakota cuts out going uphill
Old Dec 13, 2007 | 10:36 PM
RWFrazier's Avatar
RWFrazier
Default Dakota cuts out going uphill
I got a problem with my 94 Dakota and I am worried it might be the fuel pump. When I start going up hill it cuts out, just like it is running out of gas. This has happened to me a few times now. At first I thought that it might be caused by the amount of fuel I had in the tank. The way I was thinking was when the fuel level got down to a 1/4 or less and I started going uphill the fuel would all go to one end of the tank and the pump just could not pump the fuel. But tonight I was coming up a Mtn rd and the fuel gage said I had 1/2 a tank, it started to cut out on me just like I was running out of fuel. So in an act of desperation I quickly backed into and up someone's drive way and the motor started to run much better, I reved it up a few times and took off. Lucky for me I made it home. I just can't figure it out. Kinda scary cause I have to drive 50 miles to a training class in the morning.
P.S. I have actually changed the fuel pump out back in 2000
Old Dec 14, 2007 | 12:19 AM
alterboy's Avatar
alterboy
Default RE: Dakota cuts out going uphill
i think there is a tsb. look for the tsb about fuel problems.
Old Dec 14, 2007 | 07:59 PM
housedragon's Avatar
housedragon
i got a '96 dakota doin the same thing....Hey alterboy, what's a a tsb?
Old Dec 15, 2007 | 01:51 AM
alterboy's Avatar
alterboy
Its a technical service bullitin. When there is an issue or defect that needs repaired there will be a tsb the dealership refers to for the solution to the problems. Also vehicle recalls will be listed in the tsb's as well.
use this site to get the tsb # then call your dealership for more info
http://www.alldata.com/vehicle_owner/index.jspenter your truck info then Go! Go! Go!
Hope this helps.
Old Dec 15, 2007 | 01:52 AM
V8DAKOTAV8's Avatar
V8DAKOTAV8
tsb stands for Technical Service Bulletin. car manufacturers put them out to dealerships and garages and what not when there is a known problem with a vehicle. It basically gives you a good idea of where to start looking when you have a problem.
Old Dec 18, 2007 | 01:51 PM
wingerak92's Avatar
wingerak92
my 90 dakota had the same problem.. it was just a batch of bad gas that i got.. so that might be your problem.. that was actually the only time i did not use petro-canada gas in her either.. dont put esso in her
