abs and psrking brake
Old Dec 22, 2007 | 09:22 AM
slugshot_90's Avatar
slugshot_90
Default abs and psrking brake
last night i was driving down a dirt road with my friend in his car, we were going pretty fast and i pretty slammed the brakes to stop at the stop sign, we continued down the next dirt road and he drifted around a croner with sand and so did i after i did it i notcied that my abs light was on and so was p brake light so i stopped and i sat there for a while i pulled the p-brake release but did nothing when i put the p-brake on the light gets brighter and then dimmer when i take it off. any one know what the problem is or shoul i go to a auto place and get it checked out
Old Dec 22, 2007 | 06:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: abs and psrking brake
There is a switch at the abs controller thattrips when there is pressure diffence inbetween front and rear brakes, itcan get stuck. There is a post on it somewhere on here. I posted a pic of it. Just unsrew and clean and installand it should be good.
Here it is https://dodgeforum.com/m_972637/tm.htm
Old Dec 23, 2007 | 12:07 AM
slugshot_90
well also my brakes do feel spongy and and no air in them will be fixed when i do this wire thing
Old Dec 23, 2007 | 12:34 AM
95V8Dakota4x4's Avatar
95V8Dakota4x4
You most likely blew out a rear wheel cylinder, or worse, a brake line. And you don't need to brag to us about your driving. I'm guessing you're a teeny bopper?
Old Dec 23, 2007 | 02:21 PM
slugshot_90
first of i wasnt bragging i was just explaining the situation so that maybe when some one goes to answer my question it can be narrowed down to the exact problem, there fore i was telling what caused it
Old Dec 25, 2007 | 12:48 AM
onephatcracka's Avatar
onephatcracka
i second 95V8Dakota4x4. check for leaks. if no leaks.. its possible a seal tore in the master cylinder.
Old Dec 25, 2007 | 09:08 PM
slugshot_90
well i just dropped my car of at a friends house who is a mechanic he said its the master cylinder so hes putting a new one in tommorow
