318 dodge carburetor choice
Old Jan 13, 2008 | 07:52 PM
mini's Avatar
mini
Default 318 dodge carburetor choice
I'm putting a 1970's 318 in my dakota (tired of the 3.9) and I was wondering what size of carb would be right for the 318, I've got a 550 rodchester that I could easily get my hands on, seems right to me. usually 600 - 650's are good for 350's and 360's.
Old Jan 13, 2008 | 08:43 PM
injmopar's Avatar
injmopar
Default RE: 318 dodge carburetor choice
I am not a fan of rochester's ,but if you have a good one 550 is fine.Remember to check your manifold to see if it has a square bolt patern.
Old Jan 14, 2008 | 08:47 PM
95V8Dakota4x4's Avatar
95V8Dakota4x4
Are you talking about a 2bbl? Because Quadrajets are all at least 680cfm or so. They're also all spread bores, which have different mounting points than square bore carbs. You need to give more details on the engine in particular. The carb size isn't just dictated by the size of the engine, it's what you have inside it that counts. A wild 318 needs more carb than a mild 350. Regardless, I'd run a 600 or 650.
Old Jan 15, 2008 | 11:30 AM
jonnymagnum's Avatar
jonnymagnum
I would run a 600 or a 650 holly
Old Jan 15, 2008 | 01:21 PM
300hp318's Avatar
300hp318
i run a 600 edelbrock electric choke. very good carburetor because it isa one piece design unlike holly, meaning it wont leak.
Old Jan 15, 2008 | 10:09 PM
mini's Avatar
mini
yeah i was talking 4bbl , alright I can pick a 600 edelbrock up for cheap too, man. choke though which i don't mind
Old Jan 16, 2008 | 12:06 AM
95V8Dakota4x4
ORIGINAL: 300hp318
Those Edelbrock carbs are just rebadged AFB's. Edelbrock bought the rights to repro the carbs from Carter. Personally if I'm going for a square bore carb, Carter/Edelbrocks are my last choice. Holley/Demon carbs are easier to work on, tune, and get parts for. And the only Holley I've ever had that leaked did so because of my own stupidity.
Old Jan 16, 2008 | 12:07 PM
OneBadKota's Avatar
OneBadKota
It depends on how it's built. If it's just stock I would go with something 600-650. Try to avoid Edlebrock, I have a 750 on my 360 and it's just junk. Holly's are pretty good.
Old Jan 16, 2008 | 04:37 PM
mini's Avatar
mini
Okay, yeah i like hollys too and i've had good lucky with rodchesters but ive only put an edelbrock on a friends truck and it worked good. thanks
Old Jan 19, 2008 | 04:02 PM
slickbC's Avatar
slickbC
Hey Guys I have 318 with a 1407 or 1405 weber carb on it. I think Its about a 500-600 cfm carb . How do i tune the Ims mixture properly. Also, I would like to know how i can soup it up a little for street driving.
