headlights..
well my headlights arent working..high beams work, low beams dont, ive got the dash apart and was looking for some help with what i should be looking at on the fuse box/power distributor. does anybody know what # fuse is for low beams? ive already checked my grounds. if i check the headlights themselves, what should i look for?
Thank you
Thank you
Check out https://dodgeforum.com/m_1129237/tm.htmfor fuses. The FAQ here in 1st gen has a wiring diagram if you need it.
Yeah, David called me today, sometime over the weekend i know a guy who willl check it out for me, hes an electrician and used to be a mechanic so he will figure it out with everything ive already learned from you guys, thanks again for the help!! and ill let you know how it goes.
