"Check Engine" flashes 18 times
Old Jan 22, 2008 | 09:00 PM
noodle's Avatar
noodle
Default "Check Engine" flashes 18 times
Welp, lately my "Check Engine" light keeps coming on. After driving around town for a while, normal temp, normal oil pressure, everything looks good. The light will come on and stay on until I shut the truck off. It will not come back on when I start the truck. It is doing this more and more. I have tried looking up how to read the codes and I cannot find them anywhere.
I did the on-off-on-off-on and I found that it flashes 18 times with a pause at what seems to be random intervals. If someone can either tell me what the 18 flashes means, or how to better read them, I would greatly appreciate it. Thanks.
Old Jan 22, 2008 | 09:04 PM
noodle's Avatar
noodle
Default RE: "Check Engine" flashes 18 times
Well I found this https://dodgeforum.com/m_63384/tm.htm and I am going to go try and read them again myself. Still any input would be appreciated
Old Jan 22, 2008 | 09:23 PM
noodle's Avatar
noodle
This is what I have come up with.
Code 12, Direct battery input to PCM was disconnected within the last 50 key-on cycles. I dont know of I read that one right because it has been at least 50 times since my battery was disconnected.
Code 32, EGR system failure. Need a new EGR Valve im assuming? Not that big of a deal to me, is this affecting my performance at all?
Code 55, End of error messages. Cool.
Suggestions?
Old Jan 23, 2008 | 12:32 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya 32 is the only code you got. It can affect mpg and emissions. Check all hoses and wires.
Old Jan 23, 2008 | 01:35 PM
Nicegy525's Avatar
Nicegy525
remove the EGR valve and clean it out with parts cleaner. otherwise you can spend the $200 for a new one.
A clogged EGR valve will cause a rough idle and stalling.
Old Jan 23, 2008 | 11:36 PM
noodle's Avatar
noodle
but i have just the opposite of that, i have a very smooth idle and have never stalled the truck since ive owned it. wo wtf? i guess ill clean er up anyway because i do kinda get ****ty gas milage.
Old Jan 25, 2008 | 06:02 PM
JetNoise's Avatar
JetNoise
Most of these trucks have crummy mileage...
I wouldn't worry about the 12 Code. It just read as a "Start of Codes" and the 55 is the "End of Codes."
Most EGR codes are caused by a dirty EGR Valve that isn't doing it's job quite right because it has too much carbon built up.
You can easily clean it up using Carb cleaner, if you'd like.
If you really feel like changing the valve is costs about $95 at your local AutoZone.
