Trans leak
Old Jan 29, 2008 | 06:38 PM
96dakota4wd318's Avatar
96dakota4wd318
Default Trans leak
removed pan cleaned and got new gasket this last fall...now leaking again and can't seem to stop it..gasket is pushing out the sides the more you tighten the more it leaks...any suggestions snow storm comming need the fwd..
Old Jan 29, 2008 | 07:21 PM
OneBadKota's Avatar
OneBadKota
Default RE: Trans leak
Did you use a cork gasket and tighten the bolts to specs?
Overtightening will cause it to leak quicker.
Old Jan 30, 2008 | 04:21 PM
iraqvet's Avatar
iraqvet
If you over torqued the bolts the gasket couldleak. On pan gaskets, I put a bead of RTV down on the pan to keep the gasket in place then put another bead on top of the gasket before bolting it up.
Old Jan 30, 2008 | 05:36 PM
kahanabob's Avatar
kahanabob
In addition use a rubber gasket thats what usually comes with the filter kit.
