wont start HELP
Old Apr 16, 2008 | 09:17 PM
Airmanbeard's Avatar
Airmanbeard
Default RE: wont start HELP
i had something similar. worked perfectly fine went to walmart came out no start, had it towed home checked everything spark fuel pressure everything it was all there no idea why it wasn't workin had it towed to a mechanic got it off the truck and it started just fine no codes or anything. still no idea i think it was a clogged injector.
Old Apr 16, 2008 | 11:12 PM
jlbritt1's Avatar
jlbritt1
Have you checked the fuel filter by chance? If you ran that low on gas you could have sucked some junk from the bottom of the tank. You'd still have fuel pressure, because the pump is still going strong, just no fuel getting through.
