3.9l mag to 5.2l mag swap
Old Feb 24, 2008 | 10:46 AM
Ruggels's Avatar
Ruggels
Default 3.9l mag to 5.2l mag swap
i have 2 trucks one is 3.9l one is 5.2l i have all the parts should it not be a direct swap minus the computer ... same parts rad etc are identical (i work at a auomotive distributor) so if anyone has some links on a detailed how to walk through on the swap that would be great...even any info and or ideas would be great ...
both trucks are 1992 .. only dif is one is 4x4 and one is 2wd im putting the 318 in the 4x4 ..
Any info is appreciated thanks
Kirk
Old Feb 29, 2008 | 11:41 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: 3.9l mag to 5.2l mag swap
should be a simple swap, just wire up the two extra fuel injectors and you will be good to go, i am in the process of doing the same swap on mine, so i will post anything that i run into.
