engine swap
Old Mar 22, 2008 | 02:21 PM
dive_bomb's Avatar
dive_bomb
Default engine swap
Currently I have a 3.9 auto in my 1990 dak. I am planning on finding another 3.9 with a manual and building it up, then swapping. I'm just looking for some help. I know just swapping in a 318 would be cooler, but I've always wanted to try building a fast v6. I also wouldn't have to swap suspension.
Since the 3.9 is just a shortened block of the 318, will 318 performance parts work? (such as pistons)
Do all 1st gen 3.9's have the same mounts, and will it bolt right in?
Aside from cutting a hole in the floor to fit the stick, will the manual tranny bolt right in?
I appreciate any suggestions or ideas.
Thanks,
Old Mar 22, 2008 | 03:10 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: engine swap
try KRCpeformance.com and Socaldakota.comthey have a bunch off stuff for dakotas, the only problem is you dont have a magnum v6, so it may not go as well with power.
Old Mar 22, 2008 | 03:16 PM
dive_bomb's Avatar
dive_bomb
i am going to try and find a magnum v6 actually. i'm sick of toilet bowl fuel injection.
Old Mar 23, 2008 | 12:10 AM
Bad96_3.9's Avatar
Bad96_3.9
dont blame you...lol. i am sure it can be done, will prolly just be a PITA to do.
