transmission lines?
Most any auto parts store has specific transmission hose. Just tell them how many feet you need, and they will cut it. Most everything I read says to not use fuel hose.
You can use them on the ends to help fit onto a cooler. I would not at all recommend rubber hose for a full transmission line.If something were to puncture it while driving, you'd be in trouble.. quick.
The steel lines are not that expensive and can be bent by hand.
ORIGINAL: dodgerules86
ORIGINAL: OneBadKota
The exact size of steel line changed between 1987 and 1993, but for 1987, the parts list is saying 5/16". Part number 1843253. It's 25 feet worth (bulk). Should be around $44 at the stealership, but bulk line can be found anywhere for cheaper.
If you need new adapters, the thread on the transmission should be 1/4"NPT (pipe thread) but "try before you buy."
Currently, my truck is running all hose (no metal tubing), but I have a real bad feeling about it, and will probably change that out before I drive it more than a few miles from the house.
