How can you remove the error code 33
Old Apr 13, 2008 | 10:50 AM
hitandrun83's Avatar
hitandrun83
Default How can you remove the error code 33
ac relay clutch circuit, its annoying and the only code that pops up. idiot at autozone said it had to do with my transmission?? lol read on here it has to do with air conditioning, so how is there a way to remove it, is there a realy i can just remove?
Old Apr 13, 2008 | 08:53 PM
codydakota's Avatar
codydakota
Default RE: How can you remove the error code 33
I had the same thing on my '92 Sundance which was born w/o A/C I just ignored it, didn't know how to get rid of it, still have no idea, if it just came on, try disconnecting the negative battery cable for a bit and see if it helps, otherwise if your vehicle has A/C try switching out the relay with another, or if the A/C don't work disconnect the compressor unit, that way your truck "doesn't have" A/C.
