92 pops and backfires
Old Apr 13, 2008 | 12:28 PM
dkmill03's Avatar
dkmill03
Default 92 pops and backfires
my truck will idle ok but when u give it gas it pops and backfires and runs like crap. i've changed cap, coil, rotor, pick up coil, fuel filter, plugs, and computer, nothing has helped. fuel pressure is about 30-35 while idling but when u give it gas it goes up to 40, don't really want to change the fuel pump and that not fix it. had it on three different computers and it shows no codes. any help would be great.
Old Apr 13, 2008 | 02:30 PM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: 92 pops and backfires
i would say ake it some someone who has a diagnostic computer, like the snap on solus to hook up to it. it show all of the engine parameters and stuff.
Old Apr 13, 2008 | 04:35 PM
jlbritt1's Avatar
jlbritt1
Your fuel pressure is normal, but it sounds like more of a timing issue. But just for grins and giggles, have you checked the catalytic converter? They have caused me similar problems in the past.
Old Apr 13, 2008 | 04:55 PM
mini's Avatar
mini
check timing, re gap spark plugs is all i can say. make sure vacuum advance line is not damaged or leaking.
Old Apr 13, 2008 | 09:58 PM
Bad96_3.9's Avatar
Bad96_3.9
i think the timing is all computer controlled on the magnumtrucks...
Old Apr 15, 2008 | 08:58 PM
Airmanbeard's Avatar
Airmanbeard
check your catalytic converter.
