bumpers
Old Apr 15, 2008 | 12:00 AM
Airmanbeard's Avatar
Airmanbeard
Default bumpers
alrighty, looking for bumpers wondering if 'Yota bumpers will bolt up to a '94 dakota frame? what kind of bumpers are you all running
Old Apr 15, 2008 | 12:47 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: bumpers
Im unsure if the frame is the same width, as far I know they are smaller, unless your talking about the late 90s mid size ones. But Im sure its an inch or so. If you have the toyotas brackets you could probably make it fit, just drill some new holes and it might work.
Try writing IMAGE insted of IMG. I think this site is picky on it.
Old Apr 15, 2008 | 12:49 AM
OneBadKota's Avatar
OneBadKota
Default RE: bumpers
ORIGINAL: Crazy4x4RT
CAPS don't work on here, for whatever reason. So all lower case and it will work.
Old Apr 15, 2008 | 06:27 AM
Truck Dude's Avatar
Truck Dude
Default RE: bumpers
i just took off that lower valence not too long ago...heres some pics.
[IMG]local://upfiles/80634/B648BBE4279842F0955FE59E4B092F5E.jpg[/IMG]
[IMG]local://upfiles/80634/AE83596D37B64AF5A1FED3835BBBE21C.jpg[/IMG]
Old Apr 15, 2008 | 07:50 PM
Airmanbeard
Default RE: bumpers
thanks, might be worth it for the front. crazy, where did you get your push bar from? but for the back ill probably just make one.
Old Apr 15, 2008 | 08:01 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: bumpers
My front and back bumpers are stock.On both front and back bumpers I have tooken off some rubber bump stops from a chevy at the junk yard. I drilled some holes and installed them. The push bar is custom made by me. Cut and choped a full size truck one and welded it back up.
Old Apr 15, 2008 | 08:06 PM
Airmanbeard
Default RE: bumpers
k, i think im going to be doing some custom work, no problem tho. just seein if anybody even makes bumpers for 1stgen daks.
