Oil Pressure
Old Apr 21, 2008 | 04:08 PM
KoNvIcTeR's Avatar
KoNvIcTeR
Default Oil Pressure
Does anyone know what causes your oil pressure to rise. For awhile now when i drive my 94 318 dak my oil pressure will rise to almost the end of the gauge and sit there the whole time im driving. Shouldnt the needle in the gauge only ride about half way?
Old Apr 21, 2008 | 04:23 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Default RE: Oil Pressure
Sounds like a spun bearing, although the gauge is known to be dumb. My truck used to read low, to the point where the light would illuminate, but didnt make tapping sounds from low oil pressure. Does it make any funny noises? Do you lose power? The gauge should be around half
Old Apr 21, 2008 | 05:23 PM
KoNvIcTeR's Avatar
KoNvIcTeR
No the truck runs good, no noises or vibrations or anything. Maybe the gauge broke idk. Im just kinda afraid to take on a long trip, in case something is wrong.
Old Apr 21, 2008 | 06:05 PM
bluesfool's Avatar
bluesfool
Change the sending unit just to be safe; $20 and 20 minutes of your time is good insurance! The sending unit is on top of the block at the rear of the engine.
Old Apr 21, 2008 | 06:24 PM
lghtngblt02
ORIGINAL: bluesfool
Def a good start, it is easy to unhook and unscrew from the back the engine. You might have to remove the air filter to see it
Old Apr 26, 2008 | 01:18 AM
tman21786's Avatar
tman21786
is this located in the same spot on a 89 cuz mine does the opposite mine drops to nothin at idle
Old Apr 26, 2008 | 01:32 PM
Bad96_3.9's Avatar
Bad96_3.9
my old sending unit did that and went out one day going down the road and started shooting oil all over the place!!! not a bad idea to change it!!!
Old Apr 26, 2008 | 03:38 PM
codydakota's Avatar
codydakota
Sounds like a sending unit to me too, and if it isn't, it's $20
