Torsion bars.....again! llol
Old Apr 22, 2008 | 10:54 PM
Truck Dude's Avatar
Truck Dude
Default Torsion bars.....again! llol
ok, so i searched a few threads and i know about the front 2 T-bars. my truck sits about 2 inches lower in the front then the back (its a 4x4) and i would like to crank the T-bars and raise the front more...but is there a way to raise the back up too without buying a lift, i would like to lift it 2' all the way around if i could? anybody have any input, thanks.
Old Apr 22, 2008 | 11:34 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: Torsion bars.....again! llol
There is a few ways to lift the rear. Like lift blocks. $20 kit. Add a leaf $20 kit. Air shocks $80. Air bags $200Add a leafsprings from a larger truck. For example I have a rams 2500 rear springs. It lifted it. Shorter shackles $20 kit. There is no simple tricks like the front. But there is plenty of cheep tricks.
Old Apr 23, 2008 | 11:22 AM
fishlessman's Avatar
fishlessman
i cranked up the torsions and added coilover shocks to the front and airs to the back. if your going to be hard on the truck off road i wouldnt recomend the airs. once you raise the truck get it aligned
Old Apr 23, 2008 | 06:28 PM
fox's Avatar
fox
do you crank the torsion bar bolt all the way tight or do you have to measure and see if you got the 2" lift?
Old Apr 23, 2008 | 06:45 PM
Airmanbeard's Avatar
Airmanbeard
i did this a long time ago and i ended up cranking them to max to get 2" out of it. also did it to my dads '94 chevy 1500 4x4 to level it off
Old Apr 23, 2008 | 07:53 PM
Truck Dude's Avatar
Truck Dude
yeah, i think im going to crank the T-bars to level it off then put a 2" body lift all around. with the body lift, will i have to worry about the wires being stretched? do i have to replace the wire harness or anything like that?
Old Apr 23, 2008 | 08:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No you dont have worry about wires or brake lines or fuel. everything will flex enough. The engine fan shroud will have to be modified. Just make a spacer bracket! easy! OH yea the best part about the install besides the looks is you will gain lots of more room in the engine compartment.
Old Apr 23, 2008 | 08:45 PM
Truck Dude's Avatar
Truck Dude
lol, engine compartment room=good and sounds easy enough. you dont happen to have a pic of the bracket that has to be made, do you? (seeing as though you lifted your truck)
Old Apr 23, 2008 | 10:47 PM
Crazy4x4RT's Avatar
Crazy4x4RT
No unfortintly I dont because I switched to electric fans before that! But I did put a kit on my cousins truck, which was incuded. Look for some pics for a body lift for a 97 or so chevy 1500 4wd.
Old Apr 24, 2008 | 06:38 AM
Truck Dude's Avatar
Truck Dude
i might switch to an electric fan, not sure yet but thanks for all your help everyone!
