U-joints replacement
Old Jul 24, 2008 | 10:00 PM
fwtc's Avatar
fwtc
Default RE: U-joints replacement - Please help
the two joints are the same. i don't understand why you have two different part #'s and one joint smaller. on my 89 4x4 the're interchangible. i'm 99% sure yours should be the same.
Old Jul 25, 2008 | 11:21 AM
DukeSupes's Avatar
DukeSupes
I talked to the dealership on this and they said that since I have the extended cab / Heavy duty axle - tow package etc etc. This required a stouter driveshaft. But they agreed that it normally a smaller one would have been used.
Old Jul 25, 2008 | 03:05 PM
RussellH's Avatar
RussellH
I hate it when this type of crap happens, especially when you're trying to be proactive in your maintenance and after the fix the car gets worse.
Just a thought, most driveshaft's are balanced with counter weights and before you take them apart you have to mark their relative position. Though since you'rs is a single piece I suppose this wouldn't apply.
Old Jul 29, 2008 | 12:10 AM
DukeSupes's Avatar
DukeSupes
Test
Old Jul 29, 2008 | 12:23 AM
DukeSupes's Avatar
DukeSupes
Is there a problem if when you spin the drive shaft sometimes both wheels will spin and other just one?
Old Jul 29, 2008 | 01:32 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No problem at all. That meens you have an open diff. That is normal. Its not best for traction, but great for streets.
Old Jul 29, 2008 | 01:36 AM
fwtc's Avatar
fwtc
you have a heavy duty drive shaft and one larger u-joint to handle the load, the other u-joint is smaller and lighter duty, that kinda defeats the purpose of heavy duty. either the engineers at dodge who designed the dakota'sare dumb as a post or the dealership gave you incorrect info.check around at other parts places and see if the numbers are the same, if there not then check your shaft to see if any weights came off oralso check for grease or undercoating on the shaft to through it out of balance.
because it's heavy duty you may have a locker in the rear. raise the rear of the truck, spin one of the rear tires, if they spin opposite directions you have an open diff. if they spin the same direction you have a locker ( if you want to be sure call the dealership and give them the vin #, they can tell you if it has a locker) a bad locker could cause a shake but i'm not sure because i've never had one, i've heard of them exploding or seizing solid but not shaking.
Old Jul 29, 2008 | 10:56 AM
DukeSupes's Avatar
DukeSupes
Dealer decoded the Vin and the differential info came up as DRAS - Corporate 8.25 Rear Axle. Does this mean that I have a weak truck?
Old Jul 29, 2008 | 11:44 AM
Bad96_3.9's Avatar
Bad96_3.9
i have the same rear end and so does crazy4x4rt, and if we have not broke the 8.25 yet then it must be pretty tough, cuz i rag the hell out of mine and from the looks of it so does he, lol. mine is open too, it just means both tires wont spin all of the time, not so good fot traction at all so i have learned, just like crazy said.
Old Jul 29, 2008 | 09:32 PM
DukeSupes's Avatar
DukeSupes
Awesome! Thanks everyone for your advise!
