Misfiring code?
Old Apr 30, 2008 | 04:31 PM
Truck Dude's Avatar
Truck Dude
Default Misfiring code?
truck threw a code,
P0307-cylinder 7 misfire detected
Can anybody give me some advice? i figure its time to give the engine a tune up? i didnt hear anything and the truck was driving fine..thanks everyone
Old Apr 30, 2008 | 07:41 PM
noodle's Avatar
noodle
Default RE: Misfiring code?
yah. first thing i would do is just throw in a set of plugs and go from there, cheap and easy.
Old Apr 30, 2008 | 07:50 PM
Truck Dude's Avatar
Truck Dude
yeah,t hats what im gonna do first. i was planning on doing plugs, wires, PCV valve and filter within the next week before it threw the code.
Old Apr 30, 2008 | 09:07 PM
Bad96_3.9's Avatar
Bad96_3.9
i would go ahead and throw a distributor cap and rotor buttonon it while you are changing everything, that can help alot too. get one with brass terminals, they are better than aluminum ones.
Old Apr 30, 2008 | 11:07 PM
jlbritt1's Avatar
jlbritt1
May want to spend a little extra and get a GOOD set of wires. If not you may end up with some electronic noise you don't want.
Old May 1, 2008 | 06:02 PM
Truck Dude's Avatar
Truck Dude
good advice, thank you guys. anybody else have any ideas?
Old May 1, 2008 | 11:01 PM
indio17's Avatar
indio17
yes !. You may want to check the egr valve, the breeder, check the radiator fluid for discoloration and replace if necessary, check your air filter, watch the air houses from the throttle body, and look for any soft houses caring radiator fluid.Also to see if your engine dos trou any code at you.
Good look!!
