89 dokota air conditioner problem
05-06-2008, 10:59 PM
on
is there a way to find a plugged freon line or do start replacing ever thing
05-06-2008, 11:22 PM
RE: 89 dokota air conditioner problem
You could drain the freon. Then take each pice off one by one and use an air compresor to blow through it. You will find your clong in no time.
05-07-2008, 03:18 AM
Please remember that your truck, unless retrofitted with R-134a, uses R-12, which can only be purchased by certified tech's.
05-07-2008, 01:13 PM
on
is there one place that would be more likely to be pluged than others
05-09-2008, 12:12 AM
What leads you to believe there is a clog, versus just a low, or no, charge?
