Speaker question
Old May 16, 2008 | 10:06 AM
Truck Dude's Avatar
Truck Dude
Default Speaker question
i did a little searching and couldnt find exactly what i want. The question i have is, how many speakers are there in my 1996 dakota ext cab? cause i see theres 2 "vents" on the bottom of each door and i know theres 2 in the back. thanks everyone
Old May 16, 2008 | 10:32 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Default RE: Speaker question
There are 4 total, 2 front and 2 back, if I remember right the 2 fronts are 5 1/4" and the 2 backs are 5" x 7". You have to pull the door molding to get to the front ones. All you have to do to get to the rear ones is pop the covers (vents) off. Good luck, hope this helps
Old May 16, 2008 | 01:10 PM
Truck Dude's Avatar
Truck Dude
got it, thanks. i got my new stereo too and im in the middle of installing it, i am having trouble figuring out which wires (in the stock harness for the stereo) go to which speaker. i have the adapter that came with the new stereo but i need to know which speaker goes to what color on the stock harness. can anybody help?
Old May 16, 2008 | 02:48 PM
kahanabob's Avatar
kahanabob
i have an adapter on mine and each wire is labeled in very small print on the side of the wire on the adapter. I had to get into the sun light to be able to read it. Also for some reason my 90 has 4 rear speaker wires and 2 front speaker wires.
Old May 16, 2008 | 03:35 PM
Truck Dude's Avatar
Truck Dude
thank you much, i found a post on here (love this site) that had color coded labels.
Now she sounds awesome!!
Old May 16, 2008 | 09:30 PM
BAnders's Avatar
BAnders
i replaced my 5 1/4 door speakers with 6 1/2, and the rear 5x7 with 6x9. had a little bit of cutting but they sound awesome and no problems either.
Old May 17, 2008 | 05:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya thats what I did too. Upgraded the sizes. I also installed another speaker behind the vent that is not used on the door.
Old May 17, 2008 | 11:24 PM
Bad96_3.9's Avatar
Bad96_3.9
i upgaded my sizes too and put a 10 inch sub in the back. sounds really good in that small of a cab and not so loud it vibrates the truck apart!
Old May 18, 2008 | 01:15 AM
Mike124's Avatar
Mike124
ORIGINAL: BAnders
Do you have pictures of the install, i'm thinking of putting 6-1/2 in my dakota's front doors but i might go with 5-1/4 components front & 5x7 2-way coaxial rear.
Old May 19, 2008 | 09:09 PM
BAnders's Avatar
BAnders
i just trimmed the metal with aviation snips. cut a little then test fit, repeat. you will have to drill new mounting holes. i also put dynamat on the inside of the door--behind where the magnet would be
