Tires & Wheels Question
Old May 17, 2008 | 02:33 AM
Mike124's Avatar
Mike124
Default Tires & Wheels Question
This was a lift kit posting but after sir dumbass here found what i want lower on this page i changed it.
I want to put 31x10.5-15 or 265/75-16 on my dakato but i have dumb wheel questions.
1. Bolt Pattern
2. Stock Backspacing
3. Stock Wheel Size
4. ize backspacing should i use for 31x10.5 on 15x8 & 245/75 on 16x7
Thanks for any help
Mike
Old May 17, 2008 | 11:23 AM
Cutlass84's Avatar
Cutlass84
Default RE: Tires & Wheels Question
I can't help with all questions, but I do know later (early 90's-late 00's?) dakotas used a very strange 6x4.5 bolt pattern. Which as far as I know is only found on dakotas and durangos. I believe your factory rims are 15x7 but someone may correct me. Good luck.
I may try to do the same with my truck. You can swap front hubs and rear axles from an older dakota I think?? to get a more common 5x4.5 bolt pattern I believe. That is, if you can find a 5 lug dakota with an 8.25 rear axle, or if the 7.5 axles will swap.
Old May 17, 2008 | 05:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Well as for the 31x10.5 will clear everthing on a stock rim. You should not run into any rubing issues. When I had 31x10.5 on stock rims I didnt have any rubing issues. So you dont need to change rims and backspacing.But if you do want to change it you can get new wheels or just get wheel spacers. There are some for 6x4.5 and some to convert it to other bolt pattern sizes.
Old May 17, 2008 | 10:24 PM
Mike124's Avatar
Mike124
Thanks for help guys. I did some google & yahoo searches an found that if i run 15x8 with 4 of BS i will be fine.
Here my dakota the day i bought her.
Thanks again for the help
Mike
Old May 17, 2008 | 11:32 PM
Bad96_3.9's Avatar
Bad96_3.9
those wheels you hve are 6 inches wide. i hade to trade them in on some 15x8's. i would not put 31x10.5's on a 6 inch wide wheel, i had 245/60/15's on mine fora little while and the ballon pretty bad.
Old May 18, 2008 | 12:40 AM
Mike124's Avatar
Mike124
I'm going with Pro Comp Soft 8 15x8 Wheels w/ 31x10.5-15 Pro Comp Xtreme Mud Terrain from 4wheelparts.com
Mike
Old May 18, 2008 | 02:02 AM
fox's Avatar
fox
I wish I could get some viper rims.... [sm=shades.gif]
Old May 18, 2008 | 02:12 AM
Mike124's Avatar
Mike124
ORIGINAL: fox
Now that would look pretty badass
Old May 19, 2008 | 09:05 PM
BAnders's Avatar
BAnders
viper rims and a viper engine would be sweeeet
Old May 19, 2008 | 09:15 PM
Mike124's Avatar
Mike124
ORIGINAL: BAnders
HELL YEAH
