thinking about lifting my 4x4
Old May 20, 2008 | 04:23 PM
Truck Dude's Avatar
Truck Dude
Default thinking about lifting my 4x4
well im planning on lifting my truck. i found this..http://www.suspensionconnection.com/...scon/642X.html
does this seem like a good product? and are there any special tools or complications i would run into if i installed it myself?? im wondering because i am only 17 and i dont wanna get half way there and have something go wrong. im sure crazy4x4rt will have a say on this
thanks guys.
Old May 20, 2008 | 05:58 PM
fox's Avatar
fox
Default RE: thinking about lifting my 4x4
Ha beat him to it! Some special stuff ur gonna need to do is some welding and cutting the fan shroud other than that its a no brainer
Old May 20, 2008 | 06:56 PM
Truck Dude's Avatar
Truck Dude
i may have a way to get it welded, but is there a way around welding it?
Old May 20, 2008 | 07:15 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Damn Fox you did! LOL
Well the weld that is required is the shifter shaft. You can take it off and take it to a muffler shop to get welded if you needed to. There is a spacer that is incuded in the kit. Other than that no other welding. The picture is miss leading. There are no bumber brackets. There are not avaible to buy extra ethier. You can just unbolt yours and drill new holes on the bracket. This will have to be done for both bumbers. It can be done later too. It will just look weird untill you do it.
A good way to do insallation is take off all bolts on one side andon the other loosen but dont take them completely out. Then get a jack and a 4x4 block of wood and jack up the cab just enough to slide the spacers underneth. The fan shroud will need to modified just like Fox said. Just make a small spacer bracket to move the shroud 2in down. And watch for fuel lines and brake lines. They willflex enough, but make sure there are no brackets holding them down to where they cant flex. And follow the instructions that are incuded and your good. I dont know if you know, but one great benift of doing this lift kit is more engine space. The distruter is so much easyer to get to, along with engine+tranny bolts. Good Luck!!
Old May 20, 2008 | 08:32 PM
codydakota's Avatar
codydakota
Be sure to post pics of your progress
Old May 20, 2008 | 10:21 PM
Truck Dude's Avatar
Truck Dude
i plan to order the kit next week or so..ill let you guys know the progress. thanks for the help again!
