bagging 94 dakota
Old May 24, 2008 | 12:51 AM
ryan340dart's Avatar
ryan340dart
Default bagging 94 dakota
How much would it cost to put air ride on my truck?
Old May 24, 2008 | 09:52 AM
Bad96_3.9's Avatar
Bad96_3.9
Default RE: bagging 94 dakota
well they dont make a speific kit for these trucks so it would probably be pretty expensive.
Old May 24, 2008 | 10:02 AM
batman13's Avatar
batman13
you could do it for around 1000-2000, assuming you do most of your own work, and thats if you buy brand new, high quality parts
im lookin at 3k and thats all new parts, digital management, F.B.S.S. Au tanks,stainless line, dual tanks and comps
Old May 24, 2008 | 04:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here it says its around $1500 For a complete kit. pumps and all. http://airbagit.com/advanced_search_...p;inc_subcat=1
Old May 24, 2008 | 05:20 PM
batman13's Avatar
batman13
those kits are more work than doing your own.
airbagit, or AIM. make garbage kits, they are cheap for a reason, made in some back room in china, stuff breaks, welds crack.
its your money but when it comes to air, if you go cheap in the wrong place you can die, ever see a frame back half break off at freeway speeds? or drag through your rack/pinion at same speed? or even the gas tank? (that ones ugly)
you can bolt that kit on, you will lay frame,crossmember,exaust and gas tank, air is not as simple as it looks.
