question with amp
Old Jun 14, 2008 | 12:13 PM
95dodgesport's Avatar
95dodgesport
Default question with amp
im running a 10 inch sub in the back of my dakota.... problem is i cant get the amp to come on..everything is new.... all the wires are ran properly, and i know the ground is good..im stumped i dont know what else to check..i checked all the fuses in the amp, radio, and the power wire and they are all good..can someone help.
thank you
Old Jun 14, 2008 | 12:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: question with amp
Maybe the amp is defective.
Old Jun 14, 2008 | 12:40 PM
zman17's Avatar
zman17
Did you check for voltage on the supply wire?
Old Jun 14, 2008 | 12:44 PM
zman17's Avatar
zman17
And I don't know what you grounded it to, but try different locations.
Old Jun 14, 2008 | 03:56 PM
Bad96_3.9's Avatar
Bad96_3.9
do you have your remote wire hooked up? the amp will not turn on unless the remote wire is ran, it is like a relay type thing inside the amp that tells the amp when to come on. that sounds like your problem to me.
Old Jun 14, 2008 | 06:57 PM
LowClassicDC's Avatar
LowClassicDC
i have 4 12's in my dakota and i ran into the same problem, i ran all the wires perfectly, and then it cut out and wouldnt work, i believed the amps were done or something, both amps wouldnt turn on, i figured it was a ground problem, but what the problem was that the power cable wasnt tight enought on the battery post, make sure to check your fuse and your RTO the tiny blue wire, and a good gound is on the seat studs that come threw the floor if that helps any
