Sputtering
Old Jun 21, 2008 | 10:12 AM
bpscgc's Avatar
bpscgc
Default Sputtering
I have a 91 Dodge Daokta 5.2 liter and I loose power and it backfiresthrough the carb. I have changed the fuel filter, added the faucet (?),had the injectors and induction cleaned and I also removed and replaced the cat. converter. This does not happen everyday, but when it does I have to turn the truck off, let it sit for a minute and then restart. It is a pain in the butt and I can not seem to figure out the problem. HELP!!!
Old Jun 21, 2008 | 10:36 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Sputtering
Have you checked the fuel pressure with a gauge?
Old Jun 21, 2008 | 10:48 AM
bpscgc's Avatar
bpscgc
Just had the fuel system cleaned. Shouldn't they have check that? What should the pressure read?
Old Jun 21, 2008 | 11:19 AM
zman17's Avatar
zman17
Between 30 and 40 pounds at idle.
Old Jun 21, 2008 | 11:22 AM
zman17's Avatar
zman17
There are so many different things that could be wrong it's crazy. You should get a Haynes or Chilton manual.
Old Jun 21, 2008 | 11:24 AM
zman17's Avatar
zman17
And also if you have injectors you have a throttle body , not a carb.
It could be crank sensor, cam sensor, or pcm. Or timing chain.
Old Jun 21, 2008 | 11:30 AM
bpscgc's Avatar
bpscgc
k- my boyfriend is outside so I am the question girl. So if we have a throttle body could something else need to be checked? He is currently checking the vac hoses, and is going to drop the tank and clean it. We got the truck from a guy who drove it like once a week to the store a block from his housde so we are thinking gunk in the tank clogging the filter? Going to borrow a gauge to check the pressure.
He going nuts with this truck. Any suggestions as to what anyone might think or we should check would be great. Have manual but can't seem to find the damn thing.
Old Jun 21, 2008 | 11:33 AM
zman17's Avatar
zman17
If you have a manual check the IAC and TPS on the TB . Take them out and clean them . Clean the IAC first and try it.
Old Jun 21, 2008 | 11:38 AM
zman17's Avatar
zman17
Also , is the CEL on ? Read the manual and it will tell you how to check for stored codes. You say you replaced the cat. converter , but what about the 02 sensors?
Old Jun 21, 2008 | 11:42 AM
bpscgc's Avatar
bpscgc
misplaced manual - he is driving himself nuts looking for that too. Is there an free online one? Didn't replace cat, removed, did the same thing so he put it back on. Girlfriend asking this so I don't bug him - whay is CEL, IAC and TPS? If he has to answer me he the might go nuts. I am the curious/learner type, who is trying to help.
