abs
Old Jul 2, 2008 | 07:55 AM
SLT Dakota's Avatar
SLT Dakota
Default abs
how can i fix code 7 abs
Old Jul 2, 2008 | 09:09 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: abs
Check again, I don't see a code 7 anywhere.
Old Jul 4, 2008 | 08:10 AM
zman17's Avatar
zman17
Default RE: abs
Ok found it. electronic control module fuse pellet open, isolation output missing or valve wiring shorted to ground. HTH
Old Jul 4, 2008 | 09:23 AM
Lroy's Avatar
Lroy
Default RE: abs
Zman, did you ever figure out what "electronic control module fuse pellet open, isolation output missing or valve wiring shorted to ground" meant? If you did, my '96 is throwing a code 13, "...phase lock loop failure".
WTH that means?
Any clues. Any body ?
Old Jul 4, 2008 | 10:21 AM
zman17's Avatar
zman17
Default RE: abs
I could not find any troubleshooting tips, but a fuse pellet is a fusible link IIRC.
Old Jul 7, 2008 | 07:03 AM
SLT Dakota's Avatar
SLT Dakota
Default RE: abs
95 dakota i have power to computer rear wheel abs only. i have a feeling thevalve is not working, brakes work great .
