'94 dakota codes
Old Jul 3, 2008 | 08:32 PM
drpmdc's Avatar
drpmdc
Default '94 dakota codes
I have a '94 dak with a 3.9 and auto, it is having trouble running and I checked for codes using the check engine light and it flashed a 24. If anybody has a list of codes or at least knows what 24 code is please share.
Thank You
Paul
Old Jul 3, 2008 | 08:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: '94 dakota codes
Under the FAQ at the top of this section, is a list of codes. https://dodgeforum.com/m_63384/tm.htm
24 Throttle Position sensor out of range
Old Jul 3, 2008 | 09:26 PM
drpmdc's Avatar
drpmdc
Thank you, that will be a big help.
Old Jul 3, 2008 | 09:28 PM
Shelbytruck's Avatar
Shelbytruck
Throttle Position Sensor voltage either low or high. Get some Lectramotive and start spraying all the connectors. Pull them apart, spray away, work them together, and pray. Maybe you'll solve the problem... and, maybe not. Good luck.
Old Jul 3, 2008 | 10:03 PM
drpmdc's Avatar
drpmdc
I will give this a try this weekend and see what happens. Thanks for the help.
Paul
