transmission noise: slight,irregular ratcheting
Old Jul 10, 2008 | 10:06 AM
bookburn's Avatar
bookburn
Default transmission noise: slight,irregular ratcheting
My '94 Dakota SLT, 3.9, with 64K miles, tranny fluid and filter replaced 500 miles ago, but no bands adjustment, now has a couple worrysome noises.
1. Over 20 mph get slight, irregular but constantlow-pitch rattle in all gears and neutral. Got a diagnotic from shop tht no noise from drive train-read end, could be tires.
2. Now am hearing tiny, irregular ratcheting while at stop any gear. Disappears if selection lever moved a bit.
What's my next step,adjusting my bands and checking for broken bits inside?
Old Jul 10, 2008 | 12:34 PM
kahanabob's Avatar
kahanabob
Default RE: transmission noise: slight,irregular ratcheting
checking for broken bits inside should have been done when you had the filter changed. I would take it to a indepentent tranny shop and they can drive it and most likely tell you what it is. I would suspect the planetary gear assembly.
Old Jul 10, 2008 | 08:21 PM
codydakota's Avatar
codydakota
The planetery sounds like the problem to me as well
