1988 Dakota 4x4, no electric to coil, etc.
Old Jul 10, 2008 | 07:59 PM
Jeffin8tor's Avatar
Jeffin8tor
Default 1988 Dakota 4x4, no electric to coil, etc.
Hello,
I have a 1988 Dakota 4x4, 3.6L V6 that doesnot have any fire, and there is no power to the coil. It turns over, but I do not hear the fuel pump fire up when I turn onthe key. Can anyone help?
Thank you,
Jeff
Old Jul 10, 2008 | 08:20 PM
codydakota's Avatar
codydakota
Default RE: 1988 Dakota 4x4, no electric to coil, etc.
Does that have an auto shut down relay on it? Start there, I had the same problem with my '92
Old Jul 10, 2008 | 08:30 PM
Jeffin8tor's Avatar
Jeffin8tor
Where is the relay?
Old Aug 5, 2008 | 12:40 PM
hounddogg2001's Avatar
hounddogg2001
Try the ignition switch. I had the same problem with my '94 Dakota. It was the ignition switch after I checked all the wires and the ECM.
Old Aug 5, 2008 | 09:20 PM
fwtc's Avatar
fwtc
the 88 does have a shutdown relay. it's located on the inner fender, drivers side. small black box with 4 wires plugged into the bottom.
