no back brakes
Old Jul 27, 2008 | 01:31 PM
ib4shore's Avatar
ib4shore
Default no back brakes
I don't have any back brake pressure. I tried to bleed but no fluid coming out. Would this be a master cylinder problem?
Old Jul 27, 2008 | 01:33 PM
ib4shore's Avatar
ib4shore
Default RE: no back brakes
Sorry didn't specify 92 Dakota drum brakes
Old Jul 27, 2008 | 02:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be rotted brake line or bad WC.
Old Jul 27, 2008 | 02:44 PM
zman17's Avatar
zman17
Check the rear lines for leaks and remove the drums and check the WC's
Old Jul 28, 2008 | 08:40 AM
Bad96_3.9's Avatar
Bad96_3.9
yea, i would say check the lines for kinks and stuff, and if you have good pressure up front and none in the back i would check the proportioning(yes that is spelled right, i even googled it to make sure) valve, that is what splits everything back to front
Old Jul 28, 2008 | 05:33 PM
zman17's Avatar
zman17
It's also possible that the rear brakes are warn need adjusting
Old Jul 28, 2008 | 06:47 PM
milky9788's Avatar
milky9788
I had the same problem on my 92...i let both of my rear drums bleed at the same time until i saw fluid coming out and they basically bleed themselves out and then i tighten the bleeders back up and add fluid...thats how i got mine to work you might give it a try
