suspension liftq
Old Jul 29, 2008 | 12:57 AM
airhead259's Avatar
airhead259
Default suspension liftq
im planning on doin a 4inch supension lift to my 93 dakota does anybody know of any good sites to buy a lift kit from and how difficult is it to install?
Old Jul 29, 2008 | 01:22 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Default RE: suspension liftq
Heres the best post! I put it at the top.
https://dodgeforum.com/m_1066481/mpa...tm.htm#1066713
Old Jul 29, 2008 | 01:50 AM
airhead259's Avatar
airhead259
thanks crazy
Old Jul 29, 2008 | 01:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No Problem!
Old Jul 29, 2008 | 02:14 AM
airhead259's Avatar
airhead259
hey crazy i have a question for ya wat kind of wheels are u using on your dak i have had a hard time trying to find some that will fit our odd bolt pattern?
Old Jul 29, 2008 | 02:25 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I accully have stock. I had mine power coated black. But for my slicks I bought some wider ones from 4wheel parts. Most places wont have it for pre 97 but the 2nd gen they are the same.
Old Jul 29, 2008 | 02:29 AM
airhead259's Avatar
airhead259
so you can have 33's on a stock rim what size exactly would fit the stock rim i have the 15" aluminum wheels on my dak
Old Jul 29, 2008 | 02:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Most likly your width is 6in. My tires are pushing the limit. I got 33x12.5r15. So 12.5 is the widest. If you get 35's that is not wider than 12.5 it would work on that rim too. But I do have to have my tires aired down to 30psi to keep it from riding only on the center. tire psi is suposto be 55.
Old Jul 29, 2008 | 02:49 AM
airhead259's Avatar
airhead259
ok thanks that helps alot one thing have u had a decrease in gas milage with the bigger tires or did it stay the same?
Old Jul 29, 2008 | 02:55 AM
Crazy4x4RT's Avatar
Crazy4x4RT
For me it stayed the same. But I Did change my gear ratios to make up for the larger tires.
