Rod knocking?
Old Aug 1, 2008 | 04:49 PM
DukeSupes's Avatar
DukeSupes
Default Rod knocking?
Is there a way of testing for a bad rod? My truck has developed what sounds similar to a rod knocking noise when sitting at a certain angle or sometimes when you hit the gas from a stop.
Old Aug 1, 2008 | 11:08 PM
fox's Avatar
fox
Default RE: Rod knocking?
disable the spark plug wire on the cylinder you think it is and if the noise goes away when you disable that cylinder its most likely rod knock
Old Aug 1, 2008 | 11:09 PM
Bad96_3.9's Avatar
Bad96_3.9
make sure is is coming from the bottom of the engine. it could be a lifter tap. how is your oil pressure? is sounds l i k e it is starving for oil by the way that you described it.
Old Aug 1, 2008 | 11:30 PM
fwtc's Avatar
fwtc
take a 3/8 steel rod, put bit against each cylinder and your ear. if its only one cylinder its probably the rod. if its everywhre than it could be the o2sensor. mine ran rich and it sounded like a bad rod.
