Help
I need to know where I can get a Fiberglass Cowl Induction Hood for a 1994 Dodge Dakota Club Cab. Also I have some transmission problems. The truck has a 318 with a 5 speed that came from another Dakota that had a V6. Now the transmission is grinding when I shift from second to third and third to fourth. Also it's sometimes grinding when the transmission is in neutral. It will also grind when I put it in reverse and start backing up and when I put in first and pull forward it only grinds in first and reverse after I have taken my foot off of the gas pedal, and coast.
http://www.dakota-durango.com/parts_hoods.php#AAR2
Or jegs.com and get add ons.
Your tranny problems sounds like your sincros are shot. Its time for a rebuild!
