90 Window Replacement
Old Sep 30, 2008 | 09:53 PM
90Kota's Avatar
90Kota
Default 90 Window Replacement
Does anybody know a trick to getting the window back into the door? Do I have to pop the rivits out of the glass from the salvage yard?
Old Oct 2, 2008 | 02:21 AM
Crazy4x4RT's Avatar
Crazy4x4RT
DOOR GLASS REMOVAL
  1. Remove the door trim panel (or, if applicable, the access panel), the waterdam and the noise insulator.
  2. Open the window glass (move the glass down into the door)
  3. Door Beltline Moulding Weatherstrip
  1. Remove the retaining screws and the beltline weatherstrip moulding from the door. CAUTION: Damage to the window glass rear track channel is possible it the glass is removed without using Tool C-4867 (or an equivalent tool).
Door Window Glass Removal/Installation
  1. Use Tool C-4867 to disengage the window glass edge sliders from the glass rear track.
  2. Rotate the window glass on the regulator roller, slide it rearward and upward at a 45°angle, and remove it from the door.
INSTALLATION
  1. Install replacement edge sliders on the window glass rear edge.
  2. Insert the window glass into the door.
  3. Slide it forward and downward at a 45°angle.
  4. Engage the window glass edge sliders with the glass rear track.
  5. Engage the lift channel with the regulator roller.
  6. Position the beltline weatherstrip moulding on the door panel and install the retaining screws. Tighten the screws securely
  7. Install the noise insulator, the waterdam and the door trim panel (or, if applicable, the access panel).
Attached Thumbnails 90 Window Replacement-78687504.gif   90 Window Replacement-78687503.jpg
Old Oct 2, 2008 | 09:06 AM
90Kota's Avatar
90Kota
the illustrations aren't even related to a door . The text is pretty close to what I'm dealing with . I'm going to drill out the rivits and take the bracket off in order to get it in the door. I think I will go ahead and pull the seals out of the track too.
Old Oct 2, 2008 | 09:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sorry, I have no Idea what happend there! I edited it!
