help
Old Nov 7, 2008 | 04:58 PM
mopar4406's Avatar
mopar4406
Exclamation help
i got a 1994 dakota v8 and i'm having problems at idle it doesn't want to stay running i tried to get the fault code but didn't get any active
also i was checking the 4 wheel drive out and put it 4high now it doesn't want to come out of it please help
Old Nov 7, 2008 | 05:14 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Its most likly the IAC Idle Air Control valve. They tend to get stuck. Take off and clean and make sure it moves good. If you need to replace it with a new one.
The 4wd is probably a miss adjusted shift linkage. just go under and readjust.
Old Nov 7, 2008 | 05:27 PM
mopar4406's Avatar
mopar4406
yes i was just doing some investagating and came up with the samething do you have any thing on the other issue i'm having
Old Nov 7, 2008 | 06:30 PM
dodgey's Avatar
dodgey
I had the issue of my 89 wouldn't stay running and it came down to fuel injector issues ..... if it did stay running it would barely drive or if you did get it out of the driveway when you hit the gas it worked opposite where it would wanna kill unless you hit HIGH rpms
Old Nov 9, 2008 | 03:53 PM
mopar4406's Avatar
mopar4406
bingo it was the IAC thanks
