96 Roaring after fan clutch replacment
Old Nov 10, 2008 | 02:27 PM
chrizg's Avatar
chrizg
Default 96 Roaring after fan clutch replacment
Took the Dakota to a local tires plus after a grinding noise started happening during the morning startup. They said it was the fan clutch and water pump. Now that these two items are replaced the engine has a loud roar on start up and when accelerating. It did not have this roaring noise before the parts were replaced.
After doing some searching and reading online it seems this is normal to happen once the clutch bearing has spun all the fluid back out of the low spots the fan slows down. I did read that it happens more during colder weather and its getting cold in iowa. I called the wife to see if it quiets down after its warmed up and she didn't know so I am going to check it out tonight once she gets home. I don't drive it daily so I am not sure after it warms up.
Any thoughts?
Old Nov 10, 2008 | 04:30 PM
Bad96_3.9's Avatar
Bad96_3.9
probably just the fan moving air. if it disengauges when it it warm it is ok. it will always be on during the first startup though.
Old Nov 10, 2008 | 04:47 PM
iwa2002's Avatar
iwa2002
I had the same problem with after market fan clutch. Went back to OEM, problem solved. (www.oemdodgeparts.com)
Old Nov 11, 2008 | 07:18 AM
HankL's Avatar
HankL
some of the 'heavy duty' fan clutches are really for snow plowing use
and lock up at a low 140 degrees of air temperature
stock factory clutch locks up at 220 degrees
Old Nov 13, 2008 | 11:52 PM
JetNoise's Avatar
JetNoise
It's normal. Mine was loud when I got the truck... quieted down as it failed and was loud again when replaced...
It is perfectly normal.
