front brake question
i bought the new rubbers that go in the caliper bolt holes.from advance auto parts.do i need the teflon bushings or are they built into the new rubber things i put in?thats all that the store had .and on my pads i bought(duralast #MKD 529) there is a metal bracket built on like a sqeal tab if i spelled that right but it for sure is not ITS TOO FAR FROM THE PAD ...which direction should it go .on top or bottom the pad fits either way????????????thanks
Rule #1, But,it sounds like he is past that point already.
Rule #2. info about at least what year it is will get you more replies!
